roadnerd's avatar
roadnerd
Diesel Aux Tank wiring
I just scored a clean(ish) 50 gallon Weather Guard Aux tank + GPI 150s (15 GPM) pump setup on Craigslist. It will be going in my f250 (standard bed) to add a bit of range. It will not live in the truck full time, as I need the space for other stuff for "daily driving".
It seems like the easiest way to hook up the pump is just to get 12V off of the 7 pin connector that is already wired in the bed (PO setup it up to tow a 5er, I pull a TT). The only problem I see with this is the potential to have the fuel stolen, as all someone would have to do plug the pump in a start stealing. The only other real option (other than just throwing a 12V car battery in the bed when traveling), which seems like overkill, is to hook something up to an upfitter switch. This is not a DOT tank, so gravity feed is not an option.
Any words of wisdom on this?
  • I ran a power line to one of the batteries under the hood. I use a couple of large alligator clamps to attach the line to the battery when I want to pump. I've thought about putting in an inline switch, but just have never gotten around to it. :) I hadn't considered plugging into the 7 way plug, but that's a good idea. Except of course I have my toyhauler plugged into it. :)
    It's got a good filter on it? I worry a little about getting condensation and gook in the tank, but so far so good.
  • I have a very similar setup for my truck. I just wired in a 7 way plug for plugging into the in the bed recepticle with quick connects close to the male plug end. In a matter of a few seconds, I can pull the plug to stow away in the rear truck door storage pocket.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
