roadnerd's avatar
roadnerd
Diesel Aux Tank wiring
I just scored a clean(ish) 50 gallon Weather Guard Aux tank + GPI 150s (15 GPM) pump setup on Craigslist. It will be going in my f250 (standard bed) to add a bit of range. It will not live in the truck full time, as I need the space for other stuff for "daily driving".
It seems like the easiest way to hook up the pump is just to get 12V off of the 7 pin connector that is already wired in the bed (PO setup it up to tow a 5er, I pull a TT). The only problem I see with this is the potential to have the fuel stolen, as all someone would have to do plug the pump in a start stealing. The only other real option (other than just throwing a 12V car battery in the bed when traveling), which seems like overkill, is to hook something up to an upfitter switch. This is not a DOT tank, so gravity feed is not an option.
Any words of wisdom on this?
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
