Dave_H_M's avatar
Dave_H_M
Explorer II
Aug 07, 2015
Different Tire Issue (I think)
I am on my second F250. Can't give details (weights etc)on the first one. This one came with General Grabber HST LT 245/75R 17 LR E. Max wt 3195lb. Other one had General Grabber LR E also.
On the first one, I was cruising down the road and one of the rears went off like a shotgun. Fifth wheel was about the same as the one I have now.
Current vehicle, last winter when buzzing around Charleston SC, The rear got squirrely. TP was 80 psi. Ply separation on left rear, but was able to hobble in and get spare on. On this truck, I have had it on the scales. The rear tires are a tad over 500 lbs to spare before being at max weight recommendation. Tire had 70!% tread left.
I am getting kinda gun shy about hitting the road this winter. Just me.
What do you think?
Other bad experiences with grabbers?
Should i put something else on the rear?
Chalk it off to just my luck?
etc?
  • So on dead flat ground (scale) you have ~550 lbs of tire capacity remaining. Get it on the road (crowned) or in a side wind and your are going to shift some weight to the side. I think you are overloading a tire slightly and may be the cause of the failures.
    I've had good luck with General tires (I've owned a few set with different tread patterns) but have never run them near capacity.
    Go to a different tire size/brand to get a 3450+ tire capacity, or maybe even swap to an 18" wheel for a higher tire capacity.
  • Current truck is a 12 model with the tire separating last winter.
    Sounds like you are answering your own question. Three year old truck, tire issues already. Something probably needs to change.
  • midnightsadie wrote:
    sounds like your tires are old ,even thow they have a lot of tread tires rot.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
