westend
Mar 14, 2015Explorer
Answers:
1) Incalculable because we have no idea what pressure the carpet dryer achieves. It's also not that technical. If the blower moves enough air, the test will be good. Remember, if you're raising the pressure 1" of water column, you're raising the pressure 1/14 of what's already there.
2)I would guess that the seals might hold better in the closed position. If you want to test with the slides open, it doesn't take a whole lot of effort to tape the slide sealed back to the siding. I use masking tape for sealing vents drains,etc..
3)No, those cavities will be pressurized, also.
4) Your process seems spot on. It is a lot easier than one would think, I wouldn't worry about too much pressure, your doors will be leaking, even when shut.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
