j-d
Mar 14, 2015Explorer II
Mu two Fantastic vents would not produce enough to cause bubbles at a known leak.
I've been in my coach when tested with SealTech. We could enter and close the door without sensing overpressure in our ears. As soon as we left the coach and closed the door, SealTech had it back up to a pressure which would produce bubbles. Even with no special pre-sealing and the range vent open.
Manometer could simply be a "U" of tubing, half inside the coach and half out, right? Then mark initial level at zero and look for the water to rise about half an inch, less then one inch?
CD, any idea how hard I've looked for that information?!?!? You continue to amaze me.
Doggone!!! I've finally found the ONLY reason I didn't run 50A service out to the coach. I could have a pile of used HVAC blowers tomorrow. To get one that runs on 120VAC means a furnace has to be the donor. The A/C techs also tend to keep them to ventilate attics while they work.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
