Togger
Mar 19, 2015Explorer
I also have a question regarding spray checking for leaks once I acheive a positive pressure.
One area where the leak could possibly be coming from is the joint where the rubber roof meets the aluminum gutter at the sidewall. Above the gutter there is a plastic D shaped cover piece that runs the length of the camper and covers the screws that hold things together.
Would it be necessary to remove the plastic cover of the joint to be able to pinpoint exactly where the leak is? If I do remove it, can the plastic piece be re-used and put back on or would it need to be replaced with a new one?
I'm thinking I would leave the plastic cover on but if I get bubbling anywhere along it I would have to remove it to find the specific screw or spot that leaks. Any insight to how this joint is assembled would be appreciated because I'm not sure how that seam is constructed.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
