ktmrfs
Apr 07, 2018Explorer III
joebedford wrote:
I must be more tired than I thought: .15V and .35V DUH!
well, those results are much more reasonable, but I would still expect to have well under that voltage drop with the load you are drawing, especially on the 0.35V measurement.
I'd check the connections to both the breaker and the switch. I suspect they may be corroded or loose, or if they used the typical crimp connector, a bad crimp that is becoming more resistive.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
