westend
Apr 08, 2018Explorer
The breaker was failing. The switch shows quite a bit of resistance. I'd suggest to spray some electronic cleaner into it. Caig Deoxit 5 in a spray can is what I use. It lubricates just a little but it removes corrosion.
Yes, your Grp 27 isn't going to provide much capacity even when new. Will it be enough for you, I don't know. I'd suggest to install 2 x GC2 6V as replacement. Their construction allows for longevity with RV use.
Good luck with the 12V, at least you got to inspect everything.:)
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
