johnm1's avatar
johnm1
Do I need solar or more batteries and a better charger?
OK - I'm starting to wonder if I'm looking at this wrong.
I was planning on solar and starting small with 1 or 2 portable panels and eventually put them (and more) on the roof but now I'm really wondering if that's unnecessary for my needs.
I have (2) 6V gc batteries (230AH each), all LED lights, live in NYS so no winter camping, we have a Mr Heater heater to take the chill off in the evening and then again in the morning for spring and fall camping, so no furnace needed, "Navy" showers so pump runs minimum amount of time, fridge/water heater on propane (obviously) and a couple of Maxxair fans that might be used for short runs to cool down if needed .. but we also have a TH so I can just open the back of the rig if it get's too warm, a couple portable fans that move a fair bit of air and use rechargeable D batteries and I plug into a 30A RV outlet at home 24/7 while not using the rig so the batteries get topped off between each trip.
We tend to dry camp for 3-4 day "weekends" up to 2 weeks at a time (the long ones only happen 2-3x/year)
I know I need to get actual power consumption #'s at some point but with some "back of the napkin" calculations, I'm beginning to wonder if I should just add a couple more batteries and get a different battery charger to use with my (2) Champion 2000W Inverter generators (with parallel kit).
The goal would be to go without recharging for 4+ days and then be able to recharge the battery bank within 3 hrs of generator run time. I have space for at least 2 more batteries.
BTW: The RV came with the standard WFCO 9855PEC power center thing. I have no problems with switching that to something else or just adding a clamp on style battery charger (like you'd use at home) if it would do what I want. I'd also like to not have to fiddle with power setting on the charger too much.
You thoughts please ... besides the fact that I'm nuts.
Having RV issues? Connect with others who have been in your shoes.24,270 PostsLatest Activity: Jun 17, 2025
