joebedford's avatar
joebedford
Nomad III
May 27, 2017
Does this frame cross-member break matter?
Yes, I suppose it matters. I was chasing a plumbing issue and discovered this when I opened up the underbelly of the rig. At first I thought it was one of the black tank supports but on closer inspection it appears to be a cross-member. It is a steel bar at the top and bottom with zig-zag rod welded back and forth.
It's in a very bad position near the tanks and water lines. Welding would be problematic to say the least. I wonder if a steel L with bolts would be sturdy enough?
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 12, 2026
