beaubeau's avatar
beaubeau
Dometic A/C glitch
Hi!
I have a 2013 Passport with a Dometic rooftop ducted A/C and Dometic single zone LCD thermostat.
Yesterday it was working fine.
At night, we like to leave the thermostat fan setting on Lo (not Au) so that it runs continuously through the night, for the white noise.
Last night, in this configuration, the fan turned off. I can cycle through Au, to Hi, back to Lo and the fan will come on, but still will turn off after a while.
Also, separately, I think ... I had the temperature set at 68 but the air temperature is 70. Nothing is running. So I lowered the temperature to 64, still nothing is running.
If I cycle through Furnace, Off, Fan -- the fan turns back on.
If I cycle on to Cool, the A/C compressor turns on, and the fan does too.
What could this be? I'm moving a few hours down the road today -- if this could be a thermostat problem, I could probably find one along the way.
Thanks for any help.
