kadylady wrote:
@soundguy
Thank you for posting that picture!! That is what we intend to do!
I also found that it was referred to a Climate Control.
BTW.....some have mentioned DC. This refer is a two way only fridge.
Yes, the DM2652 is a 6 cu ft 2-way fridge BUT because it's a DSI fridge it also does require 12 vdc to operate the fridge's electronics, supplied either by your battery or converter, so when running on battery only there will be some minimal draw down on the battery even in the gas mode. The other power hog is that climate control circuit but at least that you can defeat.
