sgfrye's avatar
sgfrye
Dometic fridge DM2852 No power
Ok am I missing something. My dometic DM2852 was running fine on this past weekends trip. Get home no power on 120 or dc. No lights on display, interior light nothing. What I’ve done so far:
Used multi tester on dc terminal block shows 13.7 volts. House battery is 1 12volt tests fine.
110 v outlet fridge plugged into cks out ok
Checked 3amp and 5amp fuse on control board checks ok with a “green light led” fuse checker.
Am I missing something or is next step replacing control board?
As always thanks!
  • The Thermal DISC on the burner outer stack cover was installed as part of the original Dometic recall. BUT, ALL Dometic refers built after the start of the recall have those Thermal DISC's, NOT a fuse. Some you can reset and the others when they trip you replace. Doug
    PS, when they trip does not mean you have a bad cooling unit. I have yet to find a BAD Disc and a BAD cooling unit as the cause.
  • sgfrye wrote:
    BFL13 wrote:
    There is a "thermo" and also a "thermal" Not clear what's what.
    http://www.dyersonline.com/dometic-refrigerator-thermo-fuse.html
    http://www.dyersonline.com/dometic-refrigerator-thermal-fuse-assembly-7-9cf.html
    My problem is the thermal fuse
    The thermo disc pop out on mine did not trip.
    Im buying a thermal fuse only not the 61 dollar part you linked. I will install fuse where i removed orginal fuse. Couple bucks for just the fuer
    The WIRED Thermal fuse is a FLAME fuse. If the unit catches fire from a leaking Cooling Unit AT THE BURNER, the flames melt/burn that Thermal fuse and shuts power down to the refer. In the 15 or so years since Dometic started installing that wired Fuse, I have NEVER had one fail. Doug
    Their in lines the real issue.....
    It only shuts down power to fridge AFTER A FIRE.
    :S
    :S
    NO, It kills power to the Fridge when the fuse melts. With NO source(LP flame) to keep the flame GOING, the flame snuffs out. You can have a BAD flame from a dirty burner and/or rodent/insect nests that would cause a flame flare out of the burner area and that fuse would shut down the refer also. Doug
    :S
    Your words (highlighted)......and I responded to those
    :S
    OK, lets state this. You have a Fire suppression system in your Auto or house. You complain that it only functions AFTER a fire starts:B Doug
    PS, THAT is the PURPOSE of that Flame fusible wire. To STOP the source of the flame.
  • :W I am tempted to re-quote the whole thing again and go for a record.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
