enblethen
Jul 07, 2017Nomad
Poor ventilation for the refer is a common problem why it does not cool. Yours is in a slide that makes it worse. There should be less then an inch between the outside wall and the cooling unit tubes. On top of many top vented refers is a void that causes the heat to have problems going out upper vent. You can install a curved piece of sheet metal to make a deflector to come better. I used a piece of split metal duct.
Yes, your regulator diaphragm could have a small pin hole.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
