dougrainer
Jul 08, 2017Nomad
ernie1 wrote:
dougrainer:
Is the 11 1/2" you're referring to at sea level? I was at 7,000 ft elevation and only had about 5" and the refer didn't want to light. Rv tech set the pressure to 16" and said at sea level it should be okay. What do you think?
I think you have a dangerous set up. You never change the LP pressure and never go higher than 12 inches. You either change the LP appliance orifice jet or do other modifications if needed but never change the LP pressure. BTW, most LP ranges/Stoves have their own internal LP regulator set at 10 inches. They run at 10 inches not 11.5. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
