SidecarFlip
Jul 13, 2017Explorer III
A new 2 stage regulator is about 26 bucks online. Worth a shot. Did you observe the flame after you cleaned everything? Was it burning higher and blue?
Curious, was the spiral baffle sooted up?
You cold have a partial blockage of solidified solution in the tubing. Only way to eliminate that, that I know of is replacement of the cooling unit or remove the fridge and invert it a couple times to get the blockage out and the slug back in solution... both tedious if that is what it is.
Good luck
Good luck
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
