MikeJinCO's avatar
MikeJinCO
Explorer II
Jan 11, 2016
Dometic Frig Quit
Our Dometic frig quit cooling. The boiler heats up on both gas and electricity but the absorber stays cool. Normally that indicates a lack of flow in the cooling system. The boiler operation indicates to me that all is ok on the electrical and gas side. The cooling system must have gotten plugged. I have read that prior to going after a new cooling unit I should try "burping" it for several days. Is that the right first step?
  • I feel your pain. This happen to me this weekend too! I'm getting the same symptoms. Propane and electric heating work but it doesn't cool. No signs of a leak. My RV is level and hasn't moved in years. I'm off-grid and it runs on AC during the day and propane at night. I'm looking at so called Amish cooling unit as a replacement.
    If it makes you feel any better, my heater went out the next day...
  • You might check around the coils and heater element for a yellow powdery substance. If there you probably have lost coolant. If so you need to have the coils rebuilt. It happened to me in a 2005 unit. Good luck and let us know.
  • Okay it sounds crazy but I would lightly bang on the coils to try to reduce the blockage. As stated it's only a temporary fix, but in my case it worked for a couple of years.
  • Blockage in a cooling unit is caused by overheating of the ammonia solution.
    Overheating is caused by disruption of the gravity flow
    When the solution is overheated the rust inhibitor (sodium chromate) crystallizes
    When it crystallizes it plates out on the inside of tubes
    When it plates out it disrupts the gravity flow which creates more overheating/more plating/more blockage.....it is accumulative 7 permanent
    All the flipping/rolling/burping will NOT change that.
    It may dislodge some of the blockage and allow some flow which could increase cooling BUT the blockage just ends up somewhere else.
    The crystallized sodium chromate will NOT go back into solution
    First thing to try.......
    Turn fridge off for 24 hours.
    Make sure it is level
    Unplug thermistor leads in circuit board (Upper left corner P2)
    Then start up fridge set to max cool and let it run overnight (thermistor unplugged causes fridge to run continuously....max cooling possible)
    If fridge doesn't cool down......cooling unit is bad
    If fridge cools down....replace thermistor
  • I'm not sure what the burping process involves but I had a friend who removed his fridge and flipped it upside down a few time over a day then checked it on electricity and it worked afterward.
