Old-Biscuit
May 27, 2020Explorer III
wildtoad wrote:
They make a fan that attaches in the back of the fridge that comes on when the outside temp reaches N degrees and help remove hot air from behind the unit.There is one on mine. They also make a battery powered fan that you can place inside the fridge to better circulate the cooling.
OPs fridge comes with TWO external fans....but thermostat is high
Closes at 149*F and opens at 122*F (+/- 9*F)
That means condenser gets hotter before fans kick on so more heat to remove
Thermostat/fans DC Power comes from DC Terminal Block to Relay with in-line fuse from Relay to thermostat and fans (Red Wire)
If door seals are good, drain line good and cooling unit can cool I would change out the thermostat on the far right condenser fin with one that has lower close/open tempo settings so fans come on earlier
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
