Old-Biscuit
May 27, 2020Explorer III
Garry&Gayle wrote:
The unit is 2012 model and as stated it was working fine for 7-10 days then the warming starts at around 4pm then by the am its 35 deg again, it will hold all day until around 4pm then the warming starts and progressively get worse until the unit is shut down for a day then restarted then it works fine again; this is not the 1st time it has done this. The unit has an additional cooling fan in the back also. A bad cooling unit would not work correctly at all.
OK if you say so........
Test the cooling unit and verify YES/NO
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
