dougrainer
May 28, 2020Nomad
Garry&Gayle wrote:
The unit is 2012 model and as stated it was working fine for 7-10 days then the warming starts at around 4pm then by the am its 35 deg again, it will hold all day until around 4pm then the warming starts and progressively get worse until the unit is shut down for a day then restarted then it works fine again; this is not the 1st time it has done this. The unit has an additional cooling fan in the back also. A bad cooling unit would not work correctly at all.
You misunderstood what I stated. I did NOT state a BAD Cooling unit, I stated a partially BLOCKED cooling unit. They will operate just fine until the cooling load is demanded from higher outside temps, then they do NOT perform as NEW. After 8 years of use, all those times you parked off level even for 30 minutes or more caused a slow partial block. AND DON'T TELL ME THAT YOU HAVE NEVER OPERATED OFF LEVEL FOR ANY AMOUNT OF TIME. Impossible after 8 years of use, unless it has been parked at the same level site for 8 years. They can only partial block from off level operation or from inadequate of blocked ventilation at the rear CU area. Doug (seen it all in 41 years as an RV Tech)
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
