dougrainer wrote:
wnjj wrote:
dougrainer wrote:
ChuckSteed wrote:
I’d still find the hi limit reset switch located on the stack for the burner and electric heating element and press it to reset the hi limit switch
If the Hi limit switch is tripped, you will NOT have power to the refer and controls. The OP does have power to his eyebrow board. Doug
So apparently this wasn’t the case with the OP’s fridge as he got an E3 code with that reset tripped.
True, His model must be a completely different model than the rest of the Dometics. That temp switch is supposed to kill all 12 volt power to the refer, UNLESS someone has rewired that switch. That switch usually has 2- red wires to it. His shows a red and yellow. Doug
I have no idea what other models of Dometic refrigerators are out there, but for reference, the model number on my Dometic is RM1350SLMX. I highly doubt that anyone has touched the unit since coming from the factory. The trailer was bought brand new by an acquaintance after they lost their house in a fire. They were planning on living in it until they could rebuild their house. Plans changed and they ended up purchasing a different home. They only lived in it for a couple of months and never had any problems with anything in the trailer. I bought the trailer from them a month ago and everything worked great until my 220v blunder. Anyway, everything is working great again now and the wife and I are anxious to hit the road. Thanks again for the help and input.
