Old-Biscuit
Aug 03, 2015Explorer III
Freezer working and Food section NOT.......classic symptom of a blocked/clogged cooling unit.
Unplug thermistor leads at board..........run fridge overnight.
Food section should get down in temps if no blockage due to lack of temp sensing/running continuously.
Another 'test' would be to wire electric element directly to 120V power BUT you would need to monitor stack temp....could cause fire if cooling unit was blocked.
