sunline1's avatar
sunline1
Dometic RM 2310 frig problems
97 truck camper with RM2310, works fine on electric, doesn't cool as well on propane. can't get temp down to 40 on propane.
Cleaned the burner there was a little piece of rust in one jet. the flames look good nice blue. Tapped on the flue with the burner covered, little bit of rust/carbon came down not a lot.
anyone give any advise/tips on where to go from here. just talked to dometic, of course they were no help.
also anyone tell does the flame adjust at all. Put thermo on MAX and flame is the same as when on a lower number ?
Any advise etc appreciated.
  • I have the same model in a 2008 Everest. What model is yours?.. I have had a lot of problems with mine. Mainly the temp in the defrost mode drops down to 40 degrees and lower. Some times it seems to forget to come on, so I turn it off then turn it on and reset it.I ordered a dinosaur replacement. I also was wondering how to get the eyebrow off, to check that.I just looked again at your model and seen it was not the same one I have . I have the DM1350
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Feb 01, 2025
