chevyman486's avatar
chevyman486
Dometic RM1350 refrigerator not cooling properly
My 4 door Dometic refer does not cool as low as I think it should. On good days the lower box cools to around 43 deg. Usually it stays around 48-52 deg. The freezer stays cold enough to make ice but will not keep ice cream frozen solid. Is this normal? I've tried to move the setting from 1 thru 5 and all setting seem to cool alike. Anyone have any ideas? Thanks, Ron
  • chevyman486 wrote:
    Thanks for the advice. I will probably go to a home style fridge; Gotta have my ice cream. LOL. Ron
    VERYYYYYYYYY SMART!!!!!!!! your fridge problems will be behind you.
  • Thanks for the advice. I will probably go to a home style fridge; Gotta have my ice cream. LOL. Ron
  • Agree with statements above. For reference our 1350 is in a slide & has two fans as referenced by Doug. We routinely get the main box down to 35f and often go back to a setting of 3. Lettuce freezes in the crisper. If it's in the mid 90's outdoors then we only get to 38 or 39f. In addition to suggestions above, you could check the door seals. We have developed the habit of always closing the left door 1st, making sure the 'flap' closes properly.
    Hungry grandkids also have a negative impact. They like to hang with the door open while staring at the tv....
  • 1. HAS it operated correctly for the past 3 years?
    2. IS this in a slide room?
    3. IF in a slide room the rear cooling fans (you have them) may not be operating and if so and in a slide room it will require an extra fan at the top access door. ALL 1350 models in a slide room require the upper extra fan but most OEM's do not install them. Doug
  • Don't know if this will help.......Dometic RM1350 Manual
    Freezer & fridge not cooling enough is usually lack of proper venting or cooling unit blockage.
    Venting:
    Open outside access, clean any debris, check for obstructions, check top vent for blockage...install couple of 12v DC fans (computer fans) to push heat out thru top vent
    Cooling Unit:
    Not much can be done if blockage is happening except replace with an Amish built cooling unit or replace fridge with a 'residential' fridge.
  • Jim-Linda wrote:
    What is the outside temp? Is the fridge on shady side or in sun? Do you have fan(s) in rear to exhaust heat?
    We had similar problem, changed to Whirlpool, problem solved. I realize this may not be an option for you, but the above questions are inherent for an RV fridge. Good luck
    Jim
    to clarify/paraphrase this post,what i believe he is saying is dump the absorption(RV fridge) and change to a Whirlpool(compressor fridge),problem solved.these questions(problems) are inherent for an absorption(RV fridge).
    i agree completely with these statements. Good luck,hope this solution is a viable option for you as it WILL solve your problem.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Put any fan you have in the outside vent and see if this helps. The temp of the freezer at the bottom of the back wall has to be below 15 degrees inorder for the refer to get cold enough. If mounted in a slide then you need to rework the baffles to improve the air flow plus fans.
  • What is the outside temp? Is the fridge on shady side or in sun? Do you have fan(s) in rear to exhaust heat?
    Jim
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
