bersh
Jun 21, 2014Explorer
Dometic RM2610 question
I have an older Nomad trailer with a Dometic RM2610 fridge in it. It has started doing something while operating on LP that I'm hoping someone can help with.
Quick background - I replaced the cooling unit a couple years ago and for the most part the fridge works great. Two years ago I put a new thermostat in it as it would only operate on LP, and since replacing it it will run on both.
Now to my question. I can't say for sure if this started before or after I replaced the thermostat, but regardless shortly thereafter I noticed that even though the fridge runs great on LP, it doesn't seem to get cold while running on LP. What I've resorted to doing is I get it started using electric, then switch it over to LP (I do most of my camping in remote areas without any hookups, but do have a generator).
Just wondering if there is something obvious I should look at. I've inspected/cleaned the burner, and that doesn't seem to help. There is a nice blue flame when it's running. Once the fridge is cold the LP keeps it running without an issue.
Thanks.
Thanks.
