dougrainer
Feb 12, 2018Nomad
bentSpaceTime wrote:Chris Bryant wrote:
Because the thermostat is modulating the flame, I doubt it has lost its charge, unless it only modulates at the very bottom of its range.
Have you checked the lip pressure? I would sure start with that.
I'm pretty sure I have several of those v35 thermostats, if I can find them.
How do you check the lip pressure?
You connect a Manometer and when it goes to bypass causing the LP pressure to drop. That is how a bypass LP tstat works. Doug
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
