Eyeland's avatar
Eyeland
Dometic Sealand toilet
I have A Dometic Sealand toilet that fills very slowly, no psi. The faucets and shower in the RV has good flow and psi.. Is there a screen of filter in the toilet itself? How can I check it and then make repair? Help, I got family and Grandchildren coming this next weekend. I am Glacier NP. No town near by.
  • There is a screen where the water line attaches to the water valve. The water valve is bolted to the spring and shaft assembly under the pedal. You will need to replace the water valve or pull it out and use compressed air to clean it.
  • Dometic/SeaLand make many different style of toilets
    Macerator Type
    Vacuum Flush Type
    Gravity Flush
    Etc.
    Gravity Flush have an inlet screen at water supply valve......
    Turn water supply off
    Place towel on floor under water line fitting....disconnect it
    Water valve assembly is a 'snap in assembly'
    Otherwise.......what model do you have????
  • Has it been like this for a while or all of a sudden? Any other work on the plumbing system recently?
    Pretty sure there is no filter or screen.
    Check the supply pressure, next is probably valve replacement unless it comes apart to inspect or clean.
  • Is there a shut off valve going to the toilet
    Shut off pump, drain water from lines
    Disconnect toilet make sure this valve if not clogged with sediment
