mtmtyah
Sep 21, 2018Explorer
Boon Docker wrote:donn0128 wrote:
Take the burner off, scrub it thoroughly, followed with a tooth pick thru all the burner holes. My guess ypu overflowed a pot or there is enough crud covering the holes to prevent a flame. Same thing happens on my stove at home. Easy fix.
Again, the burner isn't the problem. I initially removed the burner and confirmed no propane is coming up through the jet. If there's no propane through the jet, of course no propane is reaching the burner.
Burner not the problem.
See below:mtmtyah wrote:agesilaus wrote:
Have you taken the burner apart and cleaned all the small passages in it? Our home range does the same thing, just clean the burner and it will probably work fine. The burner may not even need a tool to take it apart, mine does not.
No propane is coming up through the jet, so the burner isn't the problem.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
