dougrainer
Sep 25, 2018Nomad
My comment about the dealer.
1. They replaced the LP Tank and the Regulator assbly and the Range.
2. Dometic did not direct them to replace the LP tank and Regulator
3. So, they replaced the LP Tank and Regulator and it did NOT fix the problem. So Dometic just sent a new range because it was easier than allowing a dealer that had no clue to continue
4. OR, they replaced the Range, it still did not work, so they replaced the LP tank and regulator and it STARTED working.
5. Regardless, of which scenario, the dealer was incompetent. They replaced parts instead of finding and fixing the problem. Doug
PS, IF the Water Heater fired up and ran, then there was enough LP/pressure/volume to run the 2 range burners. So, that would take the LP tank and regulator out of the equation.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
