mtmtyah
Sep 25, 2018Explorer
dougrainer wrote:
My comment about the dealer.
1. They replaced the LP Tank and the Regulator assbly and the Range.
2. Dometic did not direct them to replace the LP tank and Regulator
3. So, they replaced the LP Tank and Regulator and it did NOT fix the problem. So Dometic just sent a new range because it was easier than allowing a dealer that had no clue to continue
4. OR, they replaced the Range, it still did not work, so they replaced the LP tank and regulator and it STARTED working.
5. Regardless, of which scenario, the dealer was incompetent. They replaced parts instead of finding and fixing the problem. Doug
PS, IF the Water Heater fired up and ran, then there was enough LP/pressure/volume to run the 2 range burners. So, that would take the LP tank and regulator out of the equation.
Wrong. The dealer fix worked great. The problem I just fixed was totally different from the issue the dealer/Dometic/manufacturer addressed. That's my final comment on this. Your comments are not helpful here. Perhaps elsewhere, but not here.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
