- kneal44Exploreri used a small piece of metal tubing and sharpen the edges and use it like a punch.. cheap and throw away.
- msiminoffExplorer II
danjamm wrote:
How do you drill a hole through fabric without the fabric getting wrapped around the drill?
I suggest you invest in a set of hollow punches… they're inexpensive, easy to use, and work great.
Cheers,
-Mark
- ctpresExplorerWOW! I gotta admit that was a LOT of good and new to me answers.
- pianotunaNomad IIIUse a couple of drops of water thin crazy glue (on a horizontal surface).
- carpetguy2Explorer
Francesca Knowles wrote:
If the fabric is synthetic, I use a soldering iron. Makes a perfectly round hole with "sealed" edges- no frayed threads.
Getting the drill bit hot with a lighter works well too. - Horizon170ExplorerMostly in carpet I just cut a + where the hole is to be drilled.
I also have hole punches for cutting washers,
http://www.amazon.com/Heavy-Hollow-Punch-Large-Sizes/dp/B0002T87E0 - wnjjExplorer IISandwich it tightly between two pieces of wood?
- Francesca_KnowlExplorerIf the fabric is synthetic, I use a soldering iron. Makes a perfectly round hole with "sealed" edges- no frayed threads.
- trop-a-calExplorerUse an awl and poke through it.
- s1214ExplorerA good stiff tape. Tape the face of the fabric to form a more solid surface.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
