MEXICOWANDERER's avatar
Nov 14, 2014
Drilling P.C. Boards (tips solicited)
I am presently using small perforated breadboards that occasionally need the perforations enlarged for leads of larger devices such as diodes and resistors.
Do I really need carbide drills and an expensive Dremel or Skil tool (which in themselves are clumsy to handle)?
And is there a superior grade of hookup wire? I would prefer wire that it extremely soft annealed and easier to strip. I could also profit from expert advice on wire wrapping tools and accessories.
I cannot find circuits online for my rig so I am manufacturing them from scratch.
  • Used to drill P.C. boards years ago with a Dremel mounted in a small bench top drill press (that way the holes were straight), and there was less chance of the drill wandering...I don't think you'll need a carbide bit, but you will need a premium quality bit not a wallyworld special. A good bit will be sharpened properly and do a better job...I've seen cheap bits (especially small ones) that were "sharpened" backwards and tore or wore the material instead of cutting.
    What kind of perf boards are you using? I use cheap paper phenolic (usually orange, with tiny copper donuts only one side)... I get away with using a small flat bladed screw driver to ream the hole bigger at the cost of sometimes losing the copper pad.
    When I was fabricating my own printed circuit boards at home, using glass boards, I did use the fancy solid carbide drill bits in a dremel drill press. Before the dremel came along, it was a pure torture trying to drill the boards by hand with a conventional drill and conventional bits.
    You can buy second hand carbide bits in quantity dirt cheap from a popular online auction site. They're not sharp enough for the high speed CNC milling machines that make industrial boards by the millions, but they're fine for drilling a few holes here or there.
  • Back in the 80s I built an I/O module for my Heathkit H8 PC using standard chip sockets (not wire wound type) and used a wire wrap tool plus solder. I was able to strip about 1/4 inch insulation and wrap about 2 turns and then solder. Worked OK for a hobby but it would never last in one of your salt water stories. :B
    Should mention I also installed resistors and caps in chip sockets.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 22, 2025
