skipnchar
Jun 28, 2013Explorer
When using just the fridge (and maybe some water pump use) you should be able to go a couple of weeks but you should know that every RV will be different as they have FAR different draw on batteries with NOTHING running. Keep in mind that if you routinely discharge your "marine/RV" (read starting) battery it will give up and die quite quickly. Give it a CHANCE to hang in there for maybe a year, by not discharging greater than 50%.
Good luck / Skip
Good luck / Skip
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
