otrfun
Jul 20, 2020Explorer II
Strador wrote:If you're referring to a Micro-Air Easy Start (MAES), RV a/c manufacturers probably don't make them standard equipment because they cost $250-$300 each. As much as they would like to manufacture (and install) a MAES themselves (in-house), they cannot because the MAES is a patented device. However, some RV TT/camper manufacturers do offer it as an option.
. . . I guess my question is, why are RV AC manufactures not including easystart/software capabilities directly into the unit? Or, are there actually units out there that does this and I can’t find them? It would seem like this would be a no brainier especially with the RV power limitation?
A MAES's primary purpose in life is to make an RV a/c unit easier to start with a smaller generator (by reducing the a/c's LRA). A MAES serves no useful purpose if you're powering your RV a/c with a properly functioning, dedicated, commercially powered =>15a circuit (i.e., shore power) or a larger generator.
FYI: the MAES only functions when the compressor starts, for less than second. After that it ceases to function until the compressor starts again. The MAES has *no* effect on (and will not reduce) the continuous current draw of an RV a/c.
