sdetweil's avatar
sdetweil
electrical chassis ground screw broken
as I am finishing up the install of wiring to support my generator, I have noticed that the ground leads from the fuse panel and shore cord to the chassis are no longer connected.. the screw holding the two clamps has broken off.
somewhere on the inside of the chassis rail is the black water tank, as the drain pipe is right there and so is the release handle.
can I use a self tapping screw, or will I need to drill a pilot hole?
I have some short self tapping screws from when we did the metal roof on the shop. I think they are 1 inch.
to drop the lower cover in this area I would have to remove the retainers for the gas pipe, and take off a section about 10 ft long!.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
