Rbertalotto's avatar
Rbertalotto
Electrical Help Needed...TriMetric / Xantrex / Coffee
I have a Xantrex ProWatt 1000 installed in my trailer......4g wire less than 18" directly wired to the two 12v, group 31AMG batteries wired in parallel ....250a Circuit breaker between the batteries and the inverter
The "house" main wire is 4g to the circuit breaker / charger panel in the trailer with a 30a circuit breaker at the battery....the run is about 12'
I just bought a Keurig K130 Hotel/Commercial version coffee brewer. I went this route because this unit only draws 700 watts as opposed to all the other Keurig machines that draw up to 1500 watts. Many hotels have insufficient wiring in the rooms so this unit is designed just for them.
So....With trailer disconnected from "shore power"....running just on batteries with 280w solar panels.....when I turn on the coffee machine, drawing AC current through a "Kill-A-Watt" it shows I am using 5.6 amps......But my "TriMetric" battery monitor is showing a drain of -45 AMPS!!! In fact, at start up it goes as high as -52 AMPS.........AND..It is a sunny day and the solar panels are outputting 7 AMPS so those numbers are really -52 and -59 AMPS......
In fact, during one test I tripped the 30a "house" circuit breaker...............Very strange since the Xantrex is not drawing current through this circuit at all. It is directly wired to the two batteries.
I can't figure it out.....Why would the house breaker trip? The only connection between the Xantrex and the house wiring is both are attached to the "+" terminal on the battery and both "-" are connected to the TriMetric's shunt.
Any ideas?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
