enblethen
Jun 11, 2017Nomad
Doubt it is converter as it works when genset is running or plugged into shore power.
Could be a bad connection between the batteries and the 12 volt DC distribution panel.
Check converter output. It should be around 13 volts DC.
Check at batteries for close to the same voltage. Use a different ground connection as the battery to frame connection could be issue.
If voltage is not close check in 12 volt DC power distribution panel to isure 13 plus converter power is there on fuse going to battery.
Start following voltage drop between battery and 12 volt DC power distribution panel on both ground and positive conductors.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Aug 06, 2017
