MrWizard
Oct 31, 2016Moderator
first guess is leaky capacitors in the inverter
second guess, bad ground connection on the inverter
assuming this gfi is downstream from the inverter
you need to do the voltage testing before the gfi
at the inverter output
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
