Davidlee64's avatar
Davidlee64
Electrical Issue?
In the past several days, some electrical issues have popped up. First, the CB for the micro had to be reset. The micro was not in use at the time. Then the ice maker stopped producing ice. I reset all the breakers and it started working again. Then yesterday I went to make some coffee and there was no power to the pot, so I started looking. Everything else was working normally. I determined the problem to be the wall outlet where the coffee pot was plugged in. It is one of those Wirecon WDR outlets. I found the wires loose on the inside. The voltage readings are all over the place. I can get new outlets, but the installation tool is the problem. The only price I can find is $450 for a tool I will most likely never use again is a bit too much. I don't like the methods shown to get around using the tool. There isn't enough room in the wall for a regular household outlet. Any ides where I could rent the tool? Or come up with another idea? Thanks
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 20, 2026
