Timeking's avatar
Timeking
electrician question: voltage drop at outlet to TT
Done this for years, but now thanks to covid I can worry about stuff I never had time to worry about.
When working inside the trailer, I've been running the AC by plugging into a 20 amp outlet fed by ~30 ft of #12 to the fuse box inside the house. With no load, nothing on, I measure 0 amps and 120V at the outlet. When I turn on the AC, the voltage drops to 111, then slowly drops to 108-109 and the amps creep up from 12 to 15. So that's a 10% drop in volts, and 20% increase in amps. When I turn the AC off, 0 amps, and the voltage doesn't immediately return to 120, but starts at 118, then 119 and back to 120 in ~4 minutes. Like something is cooling down.
So what does this all mean?
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 09, 2025
