Harvard
Sep 17, 2017Explorer
If the set up is the same as ours I would suspect the magnet in the door is not close enough to the reed switch located adjacent in the door jam. You should be able to remount the magnet (using plastic spacers) to make it closer, but not touching, to the door jam.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
