landyacht318
Sep 08, 2014Explorer
eTopxizu (cheapowatt) 30 amp power supply Guinea Pig
For under 23$ and free 2 day shipping, I decided to click 'place order' on this 30 amp MW Clone
I have 2 batteries, a flooded and an AGM battery which I never discharge together, but which require vastly different charging ABSvoltages. My Schumacher has proven unreliable and simply cannot handle being a converter due to YoYoing voltage with cycling loads when batteries are near fully charged.
With this I hope to choose 14.7v, 14.9v, 15.3v, 13.1v or 13.6v depending on which battery is at which state of charge, and I will use my solar controller to do my 16v EQ sessions when the Hydrometer dictates. I really expect to use this mostly as an occasional overnight floater/power supply rather than a top charger, but of course I want that ability too.
Been considering attaching a 16$ digital Ammeter/voltmeter combo to it, or just plug in my Turnigy clone GTpower amp hour counter into it via the 45 amp Anderson powerpoles connectors, but it has a tendency to warm up and read higher voltages than exist when passing a continuous 25 amps which would make adjusting voltage a bit more tedious.
But I just saw a brand new review after ordering saying it was delivered with pieces rattling around in it. Wonder if it was somebody from here?
Anyway It should be here on Wednesday and I'll report back with my findings after hooking it up on a depleted battery and see what it can do.
It it rattles, back it goes. If it cannot go upto 15.3v back it goes. If it cannot hold 30 amps, back it goes, and I'll get the MW instead.
