- 2oldmanExplorer II
BradW wrote:
Thanks. A Honda 2k won't do that.
115V 20A - BradWExplorer IIThe thing is, does the welder really pull 20 amps? Or is that just the most it will pull on the highest setting with the largest rod? I don't know. The welder has a "High" and "Low" setting. Me thinks Low would be less than 20 amps.
- 2oldmanExplorer IIIf you want to be sure, just get another Honda!
- I thought backwoods welder was two car batteries in series, jumper cables, and some wire coat hangers.
smkettner wrote:
Does that actually work??
I thought backwoods welder was two car batteries in series, jumper cables, and some wire coat hangers. - MEXICOWANDERERExplorer
Batteries? Jumper cables? Twenty or ninety wraps of fence wire otter do it. - mcheroExplorer
My thinking after seeing that battery welder....Take the stick/rod end and connect to the positive lead of your house batteries! LOL :B - Horizon170Explorer
BradW wrote:
2oldman wrote:
Do welders have wattage?
The smallest stick machine at Harbor Freight (I think its rated at 70 amps output) gives the input as:
115V
20A
I have one of those and to put it mildly, it sucks on 120 volts. I may rewire for 220 and see what it does.
Three 12 volt batteries hooked in series for 36 volts and a set of jumper cables will work in a pinch. When on a long trip I carry some small rods and my self darkening helmet. Also battery cables to hook the batteries together. I've never had to use it in an emergency but I tried it at home with success.
I would never hook a welder to my eu2000i. - Horizon170Explorer
- MrWizardModeratorI can't stick weld, but I'm pretty fair with a wire welder
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
