ewarnerusa's avatar
Dec 14, 2015
expected normal voltage drop from load?
Is there a rule of thumb or guidance for an expected voltage drop based on amp load on a pair of 6V GC batteries? I was tinkering in my trailer this weekend and ran a 750 watt AC electric heater off of my inverter. Batteries seemed fully charged prior to this based on voltage readings, but no SG reading taken. I had a much larger voltage drop than expected, it was pulled down to 10.5V and the inverter was giving an alarm. I assume due to low voltage. Although the whole time the heater was operating and I was getting hot air out of it. I let the heater run for only about 15-30 seconds. Ambient temp was around freezing (32F). I only did this experiment out of curiosity and not out of any need. Sometimes I'm just bored and want to tinker in the camper! Inverter wired with 0 gauge wiring, about 5' from batteries. Voltage came back up to about 12.5V after removing all loads.
I think I've done this same thing before and did not have such a large voltage drop. Due to the trailer being in the repair shop all summer and the batteries being in various states of disconnect/connected but no solar/solar on but parked inside, I think my batteries took a bit of a hammering. They were like 10.5V when I hooked up the trailer to bring home. I know that's totally dead for a 12V system, but they are deep cycle and this is the first time they were ever down that low. Batteries are 2 years old. I was going to wait until spring to replace them if needed, but I also thought they seemed to be behaving fine after several days of shore-power charging and then letting my solar take over. But it does seem like they are showing a larger voltage drop for small draws (like LED lights) than I remember before this summer.
Having RV issues? Connect with others who have been in your shoes.24,285 PostsLatest Activity: Jul 16, 2025
