Chum_lee
Jun 17, 2019Explorer
The fact that your slide also delamed tells me that it's a global delam issue as far as your fiver is concerned. Its probably not just because of a roof/sidewall moisture intrusion. It could be that the water is getting in there but, IMO, it's also just a lousy laminating job to start with. (also temperature related) If you know, what did the other side look like (internally) when it was repaired? If you decide to fix it, you might want to try fixing the slide portion first. Are the end panels on the slide delaming also or are they good?
Chum lee
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
