cs2kplus
Jul 20, 2015Explorer
I emailed the website.
you are correct...part of the shaft is still on fan. The shaft was badly pitted. Looks like an ancient artifact. I ended up sawing the bad portion of the shaft away. I want to see if i can get the fan. If so - I was going to re-add the portion of the shaft and use a sleeve to joint the 2.
That's interesting info on the type of fan.
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
