partsman01's avatar
partsman01
Fixed toilet bowl seal
Well read about using vinegar in my toilet bowl as it would lose the water in bowl, sure enough poured some in let it sit, it did not go dry and after flushing a few times, it now holds water in bowl.
Easy fix.
  • bob213 wrote:
    vinegar might have removed any crud that was keeping it from sealing. We clean with vinegar and fill with olive oil between trips.
    Bowl, oil, vinegar; reminds me of a recipe. Never mind.:B
  • Gjac's avatar
    Gjac
    Explorer III
    After a while hard water deposits build up on the blade preventing the rubber seal from doing its job. I had to remove mine and s****e the deposits off before seal would work again. Even a new seal would not have held water without removing the deposits.
  • I tried all the tricks that I knew and it would eventually leak again. Took it to my RV dealer they charged $60 dollars to remove, replace the seal and reinstall including the cost of the seal. Toilet had to come out. 2008 Itasca replaced for the first time.
  • vinegar might have removed any crud that was keeping it from sealing. We clean with vinegar and fill with olive oil between trips.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
