Almot
May 11, 2013Explorer III
Fixing hole in corrugated alum siding?
Got an ugly hole, 2ft long and few inches wide, just above the bottom frame. Narrow gate, don't ask.
Covered with a "handyman's secret weapon" - duct tape, you can see it. Looks surprisingly good on grey-ish paint of the lower siding, but need something longterm. Looks are not important - I think anything but a piece of original corrugated sheet will look ugly. First idea was a fiberglass soaked in epoxy, and I'm not impressed. Eventually will work, liquid resin doesn't want to stay on vertical surface, might need "painting" it with epoxy a few times. Then sanding and painting in matching color. Should've flattened those "bumps" with a hammer before applying fiberglass - there is steel and wood frame behind. Epoxy adheres to aluminum, but after hammering it came off in places, no big deal.
Is there any easier solution? Maybe 0.125" aluminum sheet on urethane caulk (or on rivets?), as a backing, and then again fiberglass with epoxy, sanded to proper shape and painted?
