mrekim's avatar
mrekim
Flexible Hose For Water Pump
I've been to Lowes, Home Depot and a local plumbing supply shop. I've even been to a local hydraulic hose shop that also has food grade hose. I haven't found what I'm looking for yet.
I would like a single hose that is at least 3 feet long - 4' would be good with the proper fitting for the pump (1/2" FPT/FIP with the rubber compression piece I believe).
I would gladly make the fitting if I could find the proper connectors (would have to specify lead free for potable water). I feel like finding what I need should be way easier than this.
So this is what I found:
Lowes/Home Depot
All the faucet connectors had VERY restrictive openings and didn't seem like a good solution at all. They have some clear nylon hose that **might** be ok for water, but there were no fittings for the hose. I looked at 1/2" PEX fittings for the nylon hose but the ID of the hose was too large. I assume that you have to use a standard worm clamp with the nylon hose as well vs some type of crimp system.
Local Plumbing Supply
They had a 1/2 braided hose that seemed like it would work but they said that it only came in 2' lengths.
Local Hydraulic Shop
They have some "food grade" clear hose
If necessary I could make the 2' hose work or use the Shurflo silencing kit but it seems like I should be able to choose from more options. So, any suggestions on where to buy pre-made hose or hose and fittings?
