MEXICOWANDERER
Apr 12, 2015Explorer
If every single light and 12-volt battery load is switched off and a small incandescent 12-volt lamp and it flickers the same, my gut hunch tells me the converter is going psychotic. Bad connections or bad batteries act WORSE as more load is added. Tinker around with adding and subtracting the 12-volt load on the converter and see what happens...
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
